Alternator Or Battery?
beat-down69
Ok i am having some major major voltage drop. This is my setup
Kenwood HD942u head unit
2 Re Audio MX 12s in a ported and tuned box at 32htz
Hifonics 2500d
Optima yellow top under the hood
1/0 run
Big 3 done with 2/0 welding wire
Audiobahn Components in front doors and dash
Rockford fosegate 1100 watt 4 channel amp
I am wanting to know which on should i buy first a alternator with 250 to 300 amps or a nice deka or xs power etc battery with atleast 100ah and high cranking amps
Im sure both would do great but dont have the funds to buy both right now so which one would be more benifitial.
Thanks in advanced
others may have more insight, but, i can share my experience...
i was about the same as you, 2500watts, big 3, yellowtop, 1/0...
before anything went in, i put in a high output alternator, 270amp dc power
i still had voltage drops down to 11v...
so i bought batteries, now i'm steady 13.8
well, maybe, it may seem that way, but think about it as if i would have done the opposite, put batteries in first without the alt, i may have had the same issue and needed the alt... but in my experience, the alt alone didn't stop voltage drops
well a few of the local car audio shops have told me just to do batts and dont worry about the alt. They said they have been doing spl comps and have never once upgraded a alt. But in my opinoin if the stock alt cant keep the battery under the hood charged good enough to keep from droping then i dont see how it would keep 2 or 3 batts from dropping. but to me that just seems like it makes since to me but im probly wrong LOL
well, if you are really tight on cash, you are better off adding a second big agm batter because it would be 1/3 the cost of an ho alt. and it will help dramatically with voltage drop. when i didn't have the cash for a large alt this helped me out tons.
beat-down69
beat-down69
Buffalo, KY
LosIsATool
