and is it real old?
reading comprehension > youMy HO alt has been working fine for about 3 months. Now it seems to be charging at 13.7 volts. Could this be due to the weather or is my alt on its way out?
The alty is only putting out what the car needs. at the 13.?? volts you said before is fine, did you check the volts with the system cranked???My stock alt charges at 14.4 at start up and when cold. When the weather is warmer, or when the car is warmed up it's a constant 13.8 volts.
