Alternative to big-3?
ultimate157
Engineering Student
Here's my setup right now:
8-Gauge wire battery + running to my 200w rms 600 peak RF amp for my subs.
8-Gauge wire battery + running to my 100w rms 400 peak Jensen amp for my surrounds.
Both are grounded close to the amps to the chassis with a clean ground. My lights dim pretty badly with such little power. It looks like my chassis to battery ground is a mere 8-gauge wire. If I run 8-Gauge from battery - to my amps, should that fix my dimming lights?
I have a bunch of 8-gauge laying around but no 2-gauge (upgrading soon) for the big-3. This is my daily driver which is why I need a quick fix.
300w RMS total and you have bad dimming?!?
I would suggest you're alternator and/or your battery have absolutely had it, friend //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
yea, 300w rms shouldnt dim that badly... i would get my battery tested, and yea, 8 gauge upgrades wouldnt hurt, double of triple them up if you have enough, but get that alt + batt tested
xj as in a jaguar?
something's broken, or wired wrong
Ha i wish, Jeep Cherokee's model "number" is XJ. thanks for the ideas guys. The stock alternator on the cherokee is a 117 amp. I just switched the battery out for a new Orbital one, and still dims. Im guessing my alternator is on its way out //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
u could also just a capacitor for a quick fix, you wouldnt need a big one just something to give it some extra power on those hits
iono just something to think about cuz I was running like 400watts or so to my first sub with only a 90amp alt (90 amps at full rpm....) and just a small 1/2 farad cap fixed it......now unfortunatly even a 3farad cap wont fix my 9500 =/ guess 1100watts is just too much for a cap lol.....and Im way too lazy to put in the other alt right now
no no no no no no no no no no no no no no no
RRUUUNNN from the cap, if your system isnt charging properly right now, no need to add something else it has to charge up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I know, i've heard that a cap is merely a band-aid for your real problem, and i'll never run one. Even when I upgrade to 1200w rms, its gonna get new wiring and a HO alt -- no cap.
I think I'll be upgrading my alt... soon. How much are those things anyhow??
go to excessiveamperage.com i payed $390 for mine shiped the guy is really nice too. I got a 200 amp altenator for my 03 mitsubishi lancer oz rally.
My System in my 2003 mitsubishi Lancer Oz Rally (Yellow)
Iva-d310 7in touchscreen
Slim PS2, and 20gig Ipod in glove box
20gig ipod hooked up with KCA-420i
PXA-H701 5.1, dts reciever hooked up opticaly puts out 4 volts
audio control Matrix line driver after pxa-h701 outputs up to 13volts
Front speakers Crossfire X6's
Rear speakers Crossfire X6's
Subs 2 MTX 9500 12in dual 4 ohm in a custom built sealed box by Rays electronics. going to redu to the transient function of my oz rally sealed for best SQ
Crossfire 804 powering my components 100x4 4ohm
2 Crossfire 1000d's both running 2 ohms to the 9500's
200amp excessive amperage altenator
1 run of 0 guage
2 Kinetic 2400 batteries in the spare tire well hooked up to a 200amp battery relay
ultimate157
Engineering Student
ultimate157
Worcester, ma
SqJunkie
