audioarsonal
JaMarcus
It is a noob mistake to run out and buy the biggest cap they can find and think that solves all power issues.Yes caps do stbilize power but in most cases people are asking it to do more then it is designed.You need to have the power to supply the epuipment before it needs reserve.Money is better spent on batteries and alt's that produce power which gives you a better result.I have seen caps that go for $200 dollars.That money would be better spent on an extra battery then a cap.
Generally if your asking to use a cap you should probably be looking into power rather then reserve first.
