Alt Whine With Sub Amp...
The_Grimy_One
Ok, so I have a fairly simple set up. 2 way component set on 2 channels of a 4 channel amp.
And a single 12 on an amp at 4 ohms...
Well when I disconnect the RCAs from my sub amp, I have absolutely no noise. However, when the sub amp is connected, I get a decently loud alternator whine.
What might cause this? I thought that alternator whine was only introduced through highs when there is a bad ground or interference with the mid/highs amp... Didn't know the sub amp could introduce noise through the mids/highs. I have the power wire running on the opposite side of the car as well.
What should I try first to tackle this? Thank you in advance for any advice.
Grounds, grounds, grounds. Relocate the ground wire for the sub amp. Ground loops happen when the HU ground is at a different potential than the amp's ground and ground currents flow through the RCA cable's shield. And yes, the sub amp can most definitely have an effect on that. I had a similar problem on an old install and the only solution was a ground isolator. But the car was old and rusty and the trunk was far from being a solid ground no matter what I did.
U actually used a ground isolator on the sub RCAs? Thanks for the info. I am gonna step up all my ground before I put my new sub stage in.
The_Grimy_One
The_Grimy_One
Phoenix, AZ
The_Grimy_One
