Alt. Pretty Much Buried and Hidden
Put some grease on the studs - all rims need a good kick to loosen them from the hub (if your in the North East)
As for the Alt - I would guess Pass front wheel needs to be removed as does the inner liner (inner fender well) to access that part. The engineers packaged these well, but forget about fixing them
what ya mean "forgot about fixing them"?
also.. I'm thinking I can do this by just raising the car and getting underneath.. seems theres an outside chance I can find the positive terminal on the alt.
that is if my 0 gauge will just come from your site already //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I mean the engineers designed your car to "fit" together, but when something breaks - is a nightmare to get to. Got an order # I can check when it was shipped or did you get the UPS tracking number already?
aha dont worry about it bruh im in no rush.. somewhat dreading doing the Big 3.. I have a feeling somethin will go wrong.. I'm definitely going to take pics and ask for advice on here so nothing blows up..
You really shouldn't be going under your car when it is on a floor jack anyhow, you should lift it up, put jack stands under it then drop the jack. Much safer. Make sure to block your tires too and you should be good to go.
yeaa thanks.. looking into jack stands.. hopin i can nab some from my gas station for a day or two.. otherwise I might actually just roll the car up on to some wood blocks on the front two tires and get under it then
And if you the car somehow moves while youre under there...
chibahawk
oe squeezer
chibahawk
NYC
OldOneEye
