alt help? and rate my system
bigv123
i just got a 88 delta 88 and i got 3 audiobahn digital 12's 800 max (400)rms and i got a america 2600 watt 2 channel pyrimid amp with a 300 watt 4 channel pyrimid and a 6 channel crossover with and i edid all the factories but im scared to hook up the subs cuz people telling me im a blow the alt and the battery should i listen or what are my other options thanks and will that have mega bass?
what type of amp can i use to push the subs
do you mean what brand? what is the voice coil configuration on the subs? also you have a 2 channel powering all 3 subs? i know you can bridge but i can imagine 3 different subs will give you an odd impedence. i don't that amp will be stable to anything under 4 ohms bridged.
Are you sitting down? If not please do so...
Not a fan of audiobahn, but they are decent low end subs. That amp you purchased is very very low end equipment. Will not even come close to putting out 2600 watts. I would guess it is more like 600 watts total, with plenty of harmonic distortion. That 4 channel is probably 80 watts total, again plenty of distortion.
You still have the factory speakers? Why did you not upgrade them. Never mind if you kept on the path you are on. The upgraded speakers would probably not be better than stock.
You can not blow the alt or battery on 600 watts. There should be no electrical issues with those amps. Did you upgrade any of your electrical system? What gauge wire are you running?
Mega bass??? no. But as long as you like it:D
i havent hooked it up yet the 2600 is still in the box i wasnt sure if it would sound good thats why i asked the factories were all blown and what type of amp can i get to push those subs
i'll repeat. WHAT IS THE VOICE COIL CONFIGURATION? you have to know this to pick an amp. you keep saying type so get a mono block. there are so many options so you have to narrow it down. also need a budget. i'm guessing it's not very much.
bigv123
bigv123
chicago
iceteebone
