ALt Bad??
BigPimpin18
ok today I was at work all day, than I go to my car and my car doesn't have one light ocme on. I tried jump starting it and it doesn't work, so I got a new battery, the battery works just fine, and I haven't measured to see if my alt is bad. But I just installed my sub amp and I wonder if that's the cause of my problems. I have a kac-x811d to a kicker 12L74 running about 816watts. is this too much for my stock alternator?
measure the voltage with the car running. It should be around 14 volts. Autozone has a free battery/alt. checker that they hook up to your car, they'll be ablt to tell you if its functioning properly and what its putting out.
ok I measured my battery at 12 volts when the cars off, than it went to 14.3 volts while running than I drove it around my neighborhood with the sub blasting and come back and check it and it went down to 12.6 volts. I turn my stereo all the way off and it went back up to 14.3 volts. So I don't think I have a bad alternator, but I dno't think my 1 farad cap is working. But than again my lights don't dim at all. I just think I need to install a dual battery with a yellow top just for my stereo.
Go to autozone and have them test it. They'll tell you the amperage output, ect.
I'd look into a high output alt. before adding another battery. If your stock alt cant handle it now, then it wont be able to handle another battery.
BigPimpin18
BigPimpin18
Seattle, WA
jrz126
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
