ok, i did what you said and the voltage stays the same around 14.x range and then once it come down from the 2000 + range it stays at 14.x with the system off. i also tried it with the system on at full tilt and at the 2000+ range i got about 13.8-14.1 and then when the RPM's dropped the voltage dropped to 12.4 range.
I agree with you that the alt output is based off of RPM's, but the question im trying to get at is...those times when i get it to hold at 14.1+ at idle with the system at full tilt,... is that one of those max out put times or is it just the alt doing normal out put and the rest of the times i have a voltage drop because the alt is having a mechanical fault.
because i think that 180 amp draw for just a JL 1000/1 is sorta high, and i figure my car needs about 40 amps to run (stock stuff). thanks, andrew
