Alpine SWR-12D4 wiring and ohm questions
  • 2
ThunderOne
I have a sealed box that is approx 1.35 cu ft and I would like to install an Alpine SWR-12D4 into it.
http://www.sonicelectronix.com/item_45521_Alpine-SWR-12D4.html
I want to wire it so that the amp sees 2 ohms of resistance (I have an MRX-M50 so that would be 500 watts at 2ohms).
I'm not sure how to wire it, there are two ways on the interwebs that tells me how to wire it for 2ohms.
The sub is a 4ohm DVC.
Which of these wiring diagrams is correct, or better?
This one is from the Subwoofer manual, I'm assuming this is probably the correct way to do it, though I don't know what these "jumpers" are:
Also, the manual recommends a sealed box with .55-1.0 cu ft of airspace, my box is 1.35 cu ft, but the sub will only have 500 watts running to it. Will this be an issue? The sub has a 300-1000 watt RMS rating. With a 0.10 driver displacement this will knock the airspace down to 1.25 cu ft.
Thanks everyone for your help.
They're all the same the alpine sube just has its dvc-4 voice coils all on one side so i guess just to make things easy for you the top one. good luck
Ps: when you get your sub you will see included in the box are the "Jumper" wires just little wires that can plug into the bottome of the vc's. Example one will make perfect sense to you when you have the sub in hand and are looking at it. A wire will connect pos to pos and neg to neg with one wire running from each to your amp.
Thanks. Do you think my box size will be an issue?
With the amount of power you have going to it you'll be fine. But may I ask why don't you got ported? you obviously have the space to run a nice ported box considering the size sealed box ur running. Think of it like this screaming with you mouth open or closed. Ported box will make all the difference IMO.lmk if you have anymore questions ok
Thanks. Here is my current box, I'm not sure how I would go about porting it. I do prefer bass accuracy and response over loudness, so that's why it's sealed for the time being. I think if I were to go ported, I would need to buy a more powerful amp. Nonetheless, here's a pic.
Gotcha, sealed would have tighter more accurate sound quality oriented bass. If however in the future you'd like to go a little louder (which this obsession usually mandates lol) you might want to look into building/buying a ported box. For the time being I think for what you want you will be very satisfied.
272
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
574
The one set of components are spoken for. On trade with @spokey9
16
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
ThunderOne
ThunderOne
Tuscaloosa, Alabama
Fattony911
    May 20, 2024
    May 20, 2024
