Alpine SWR-1243D 2x4ohm Subwoofers
  • 2
TheRealDefman
Alpine SWR-1243D Subwoofers, 2x4Ohm voice-coils
Price is for EACH. Used, in excellent condition, less than a year old. Adult owned, not used in competition or abused in any way. Sound great and perform well, but they just took up too much room in the back of my car. Original box NOT included, the two banana plug jumpers are included.
SPECIFICATIONS
Power Handling
CEA-2031 Power Rating: 600 Watts
Power Range: 1800 Watts
RMS Power Handling: 600 Watts
Peak Power Handling: 1800 Watts
Dimensions
Mounting Depth: 162mm (6-3/8'')
Mounting Diameter: 275mm (10-13/16'')
Displacement: 0.100ft^3
Added Volume: 0.090ft^3
General
Frequency Response: 23-400Hz
FEATURES
Diaphram
Material: Kevlar Reinforced Pulp Fiber
Design: 2-Piece Structural Parabolic w/ H.A.M.R Surround (Patent Pending)
Surround
Material: Injected Molded Santoprene
Design: High Amplitude Multi-Roll
Spider
Material: Nomex
Design: Progressive
Voice Coil
Material: 180 High Temp Wire on Spiral Cut Aluminum Former
Design: 65mm 4-Layer Dual Voice Coil
Motor Structure
Pole Geometry: Compound Radius Curve (Patent #6 ,639,993)
Configuration: Radial Vented VC Heat Sink and Airflow Management System (Patent #7 ,634,101)
Frame
Material: Cast Aluminum
Design: Perimeter Vented Heat Transfer (Patent Pending), Integrated Shorting Sleeve and Airflow Management System
Terminals
Layout: One Side
Design: Heavy Duty 8 gauge Push with Housing, Banana Plug Jumper
Tinsel Leads
Design: Reinforced Layer Spider Integration (Patent #6 ,810,988)
Gasket
Design: Concealed Mount Gasket System
$90
Will ship via UPS, probably $20-25 each. PM with your full address and I will give a shipping price.
151
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
406
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
TheRealDefman
TheRealDefman
Austin, TX
TheRealDefman
    May 12, 2024
Brendon Jenness
    May 11, 2024
