nativefx
Okay, I'm trying to put a budget setup in my commuter car which is a 2015 Toyato Camry. I already have 2 sets of Hertz DSK 165.3 for the fronts and rear. I know most don't like/want rear fill but with passengers in the car normally I want sound back there as well. I also already have 2 JL Audio 10w3v3 subs that I was planning on using in my 69 Firebird protouring build but I had to make some changes due to the AirRide suspension, relocated battery and a single JL 10w6 in a custom enclosure.
I'm planning on using the factory HU as I hate how the screen and the actual knobs/buttons are separate so I just don't think it would look nice and I still want some of the factory controls in the steering wheel and from the HU. I've been researching and found I need something like the JL Audio Fix 86 or Audison Bit 10 to equalize the signal from the hu before sending to the amp(s). I don't completely understand all of this or if these are still my best option?
My question now is, what would be the best budget setup that would still sound good in my car. I was originally going to go with a PPI Phantom P900.4 for the mids & highs and then get a PPI Phantom P1000.1 to run the subs. Looking at the specs, these are more than enough power, but it means running more wires etc. to hook everything up.
The other option I recently began to look into was using a 5 channel amp that would still provide enough power for the 2 subs. I came across the Alpine PDX-V9 and from the little time spent looking for reviews, it seems to be a pretty solid amp. It says it provide 100w x 4 @ 4ohms and can provide 500w x 1 @ 2ohms for my subs. Would this be sufficient for my setup? I listen to mostly hip-hop, old school rap, R&B, and some blues while commuting and I do normally listen at higher volumes. Unfortunately the easiest option is to play Pandora via bluetooth, which doesn't really give me the cleanest sound.
Let me know your thoughts and what you recommend for what I'm considering. I'm also open to other suggestions regarding amp(s). PS - I will put some Dynomat Extreme in key areas to help with the sound.
