Alpine MRX-V70 Fuse Configuration
  • 1
SN95GT50
Registered User
Picked up an Alpine MRX-V70 (5-Channel) amp second hand, get what you pay for. Anyway, running two cheap 10" subs bridged from the sub output, no problem there. Running my rear speakers bridged, fronts running off of a different amp. Running it with a pair of RCA cables running from the head unit, balance thrown to left side, both RCA cables detached at the amp, take the left RCA.
  • Connect it to CH-1(L) got sound out of both speakers
  • Connect it to CH-2(R) got sound out of both speakers
  • Connect it to CH-3(L) no sound
  • Connect it to CH-4(R) no sound
Pulled fuses to check them, top one is fine (used voltmeter), removed second one and the fuse is broken literally only one leg came out. Leads to my first question, how are these things fused? Are the fuses in parallel and they can run off one fuse as long as the load isn't too great? If that is the case why not just run 1 larger fuse?
Finally got the leg out of the fuse holder and put in a new 30 amp fuse, now I have sound no matter what port I plug the RCA into.
Figured I jacked up the speaker wiring, checked that about a million times, left speaker is connected to CH1(+) & CH2(-) Right speaker to CH3(+) & CH4(-)
I have the Channel 3/4 switch set to 1/2 - cut and paste from the manual: "This switch setting is for selecting either 2-channel for 4-channel input mode. When set to “1/2”, signal will be copied from CH-1/2 and sent to CH-3/4, eliminating the need for y-adapters."
The only thing left that I can think of is something internal to the amp. Any suggestions for searching? I am not intimidated and am willing to tear this thing apart.
Thanks,
John
Giving subs more power really wakes them up. The MRP-500 is pretty low power. You would really notice more authority in your bass.
724
my Alpine mrx-f65 in good condition, working perfectly well, and coming complete, local pickup only Thanks
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
287
Lower price Subs: $275 shipped Only selling one set of 6.5, keeping the other $100 shipped
736
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
SN95GT50
Registered User
SN95GT50
Des Moines, IA
SN95GT50
saints747
    May 7, 2024
saints747
    May 7, 2024
