Alpine MRA-D550 DIGITAL Theater Amplifier With Accessory Cables
  • 1
Switt23
Amplifier is in Fair to Good Condition considering it's age. I have several extension cables as well as 3 modules used to hookup the amp to a needed Alpine Head Unit or Processor.
•5-channel Digital Theater amplifier
•60 watts RMS x 5 at 4 ohms
•Dolby Digital, DTS, and Dolby Pro Logic II processing built-in
•two optical digital inputs
•MOSFET power supply
•CEA-2006 compliant
•Ai-NET capable with compatible Alpine receivers
•Bass Engine® features:◦variable center-channel crossover (20-800 Hz in 1/3 octave steps, 12/18/24 dB per octave)
◦variable front, and rear high- and low-pass crossovers (20-400 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
◦variable subsonic filter (20-50 Hz in 1/6 octave steps)
◦subwoofer phase control (0/180 degrees)
◦time correction adjustment (0-10 mSec.)
◦17-band parametric EQ (five bands for front, rear, and center, two bands for sub channel)
•sub channel preamp output (20-200 Hz low-pass filter, 6, 12, 18, or 24 dB/octave)
•STAR Topology (minimizes internal noise and prevents ground interference)
•detachable front cover
•blue power LED
•fuse rating: 20A x 2
•8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
•13-11/16"W x 2-9/16"H x 10-5/8"D
$200 + Shipping / OBO
Will be shipped in original box via UPS or FedEx. Tracking will be provided once item is shipped.
581
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
815
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Switt23
Switt23
Omaha, NE
Switt23
Decebal
    Jun 10, 2024
