alpine finally came in w/ *Pics*
Umm... its a sealed box wit ~1 cu ft. per chamber after displacement. Gotta give props to InhumanAcura for buildin it.
Also I got a Hifonics 1500BX to rum both of em at 2 Ohms which is more than enough.
the place i got it from (audiovibrationz on ebay) said that they didnt have any in stock at the time. i was pissed at this but atleast they are finally here.
hey aneonrider, are you sayin that this amp isnt good enough for the subs?
subsonic = all the way to the left (in a sealed application you do not need this becuase there is no issue of the sub unloading)
bass eq = 0
low pass = 75 Hz (This one play around with until it sounds the best to you)
phase = 0 (this one is discretional, play around a little, see what sounds best in your vehicle)
Level = follow the gain setting tutorial
thanks, ill try those with some changes tommorow.
I have begun the installation process and connected one sub to test it out. It doesnt seem too loud but ill change the settings and see how it goes. It got too **** cold for me to continue else I would still be out there.
ndnbolla
Jigga what?
ndnbolla
paradise
LBX2G
michigan born
    May 14, 2026
michigan born
    May 14, 2026
