Alpine DVC Subs Instal Question
you cant just set them up as 2 ohm.
im pretty sure in your case you'll be running one amp to each sub.
what model alpine subs do you have?
if you have dual 4 ohm subs then they'll show the amps a two ohm load
if you have dual 2 ohm subs then they'll show the amps a four ohm load
think of is as you have two separate systems, each sub and amp being it's own system.
they you're set.
wire each sub to an amp like this
one sub to one amp
make sure the jumpers on the subs are connecting both red terminals together and both black terminals together. Then just get a wire from one of the red and one of the black to go to your amp, and on the amp just put the red on one of the positive connections and put the black on one of the negative.
SticBandt2004
The Illest...
SticBandt2004
Grand Rapids, Mi
SticBandt2004
AJ (ACE)
    Jun 28, 2026
