Sold Alpine CDM-7874
playa1
I bought a new clarion flip out and wanna get rid of this, i get the clarion weds so after weds is when i will be able to send it out. Had i for maybe a year & 1/2. Everything works on it, the manual can be found here http://www.restricted.alpine-electronics.co.uk/support/ownersdatabase/show.php?manual=CDM-7874RB
. Has wear from use. Also comes with this to hookup mp3 player/cd player to unit. http://www.crutchfield.com/S-lfeQAO688Oq/cgi-bin/prodview.asp?i=500KCM123B
DOES NOT COME WITH LOCKING CHASSIS $50 Shipped
Specifications:
FM TUNER SECTION
Tuning Range 87.5 – 108.0 MHz
Mono Usable Sensitivity 0.7 µV
Alternate Channel Selectivity 80 dB
Signal-to-Noise Ratio 65 dB
Stereo Separation 35 dB
MW TUNER SECTION
Tuning Range 531 – 1,602 kHz
Sensitivity (IEC Standard) 25.1 µV/28 dB
LW TUNER SECTION
Tuning Range 153 – 281 kHz
Sensitivity (IEC Standard) 31.6 µV/30 dB
CD SECTION
Frequency Response 5 – 20,000 Hz (±1 dB)
Wow & Flutter (% WRMS) Below measurable limits
Total Harmonic Distortion 0.008% (at 1 kHz)
Dynamic Range 95 dB (at 1 kHz)
Signal-to-Noise Ratio 105 dB
Channel Separation 85 dB (at 1 kHz)
PICKUP
Wave Length 795 nm
Laser power CLASS I
GENERAL
Power Requirement 14.4 V DC
(11–16 V allowable)
Maximum Power Output 50 W x 4 (CDM-7874R
only)
45 W ラ4 (CDM-7872R/
CDM-7871R/CDE-7860R
only)
Output Voltage 2 V/10k ohms
Bass ±14 dB at 60 Hz
Treble ±14 dB at 10 kHz
Weight 1.5 kg (3 lbs. 5 oz)
CHASSIS SIZE
Width 178 mm (7")
Height 50 mm (2")
Depth 155 mm (6-1/8")
NOSEPIECE SIZE
Width 170 mm (6–3/4")
Height 46 mm (1-13/16")
Depth 20 mm (25/32")
playa1
playa1
Palm springs,Florida
Twistid
