Alpine CDE-9874 going into protection mode
gmctrucks
Say guys I know beans about protection mode or clipping so what would you guys think is happening.
Ok when I turn up the volume up kinda high it shuts off for a second then it turns on and works fine when I lower the volume would it be that it's just a cheap unit or would it be best that I install a 4 channel amp on it?
Now I really like what options it has example how I can set it up for my bass oh im running a seperate amp for a 12" Kicker speaker just for bass and my other four speakers I run them for mid's and highs off the stereo internal amp the Alpine comes with. My other four speakers are 4x6 I have a 93 ext/cab obs GMC truck.
Let me add this I was thinking of disconnecting the rear 4x6 speakers and placing over the rear pillards or 4x6 speakers some of those gray carpeted boxes with some 6x9 speaker what do you experts think of that and how more power of a amp should I get to run the four speakers and would it sound clearer if I install a 4 channel amp or is it not worth the money? I hope you guys get what im trying to do here im not the sharpest tack in the box oh don't agree. LOL
Alpine iDA-X200 USB/CD/MP3 In Dash Receiver (Might this stereo be better I never use my CD player?)
Thanks guys great forum. RJ //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Alpine CDE-9874 specs Review User ReviewsSpecsCompareManufacturer: Alpine Electronics.Part Number:CDE-9874.General
Product Type Radio / CD / MP3 player .Recommended Use Car .Form Factor Full-DIN - In-dash unit .Width 7 in .Depth 6.3 in .Height 2 in .Weight 3.5 lbs .Enclosure Color Gun metal black .Faceplate Type Detachable .Audio System
Sound Output Mode Stereo .Controls Subwoofer level,
Treble,
Bass,
Volume,
Fader,
Mute,
Balance,
Loudness .Signal-To-Noise Ratio 80 dBA .Max Output Power / Channel Qty 45 Watts x 4 .Continuous Power / Channel Qty 16 Watts x 4 .Crossover Active crossover .High Pass Frequencies 160 Hz,
80 Hz,
120 Hz .Amplifier Output Details 16 Watt - 4 Ohm - THD 1.0 % - 14.4V DC - 4 channel(s) .Built-in Display LCD .Display Illumination Color White .Button Backlight Color Blue,
Red .Clock Yes (digital) .Radio
Type Radio tuner - AM/FM .Tuner Frequency Range AM: 530 - 1710 kHz,
FM: 87.7 - 107.9 MHz .Tuning Display LCD display .Preset Station Qty 18 .AM Preset Station Qty 6 .FM Preset Station Qty 12 .Additional Features DX/LO switch .CD System
Type CD / MP3 player .Form Factor In-dash unit .Media Load Type Slot-load .Supported Digital Audio Standards WMA,
MP3,
AAC .Response Bandwidth 5 - 20000 Hz .Signal-To-Noise Ratio 105 dB .Total Harmonic Distortion 0.008% .Dynamic Range 95 dB .CD-R Compatible Yes .CD-RW Compatible Yes .Connections
Connector Type 2 x Audio line-out,
1 x Audio line-in ( Mini-phone stereo 3.5 mm ) .
sometimes a simple short can cause the HU to cut out. this is prevented by improved wiring methods. no electrical tape should hold wires together. no bare copper should be visible at any connection - speaker or hu. insulated crimp terminals or solder and heat shrink are the two acceptable methods.
gmctrucks
gmctrucks
Houston, Texas
04murdalanche
