Alpine cda won't hold settings
Well the deck was perfectly fine they ended up running the constant to the cig lighter. Either way it goes I am happy because it holds the settings now.
yea see u could have done it yourself if you listened to me, i drive a cadillac seville and i had the same problem.
did they even CHECK the fuses?
i bet the fuse was blown now that you are saying that the constant wasnt working. for sure.
has nothing to do with the fuses, the wiring harness for the cadillacs bose hu's dont have a constant power wire(or coaxil antenna wire), so u have to wire it into ur cig lighter.
Yea I know but my car was recently broke into and they stole everything but my girl bought me the same stereo from them so they were going to put it in for free so I didn't even bother with it.
alot of the newer GM's aren't running the same old wiring schematic. You can't always go "... Ground to ground, Batt to Batt, Switched to Switched...".
If I wanted to wire up my aftermarket head unit to cover all the functions of my Stocker, I need a big ugly expensive harness, a relay, 2 inline fuses, and a vss adaptor.
check your terminals on your battery, specifically the negative, and make sure its securely tight, i had the same problem before only to find out the terminal was loose.
**** american cars. //content.invisioncic.com/y282845/emoticons/thumbsdown.gif.d22f25895e9b40f2300c953691dacfa2.gif
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
937
That’s really helpful, thanks! I’ll keep digging and see what I can find online :)
I'm hoping to find someone who might be able to repair this head unit. The faceplate doesn't slide out at all.
327
bmd107
bmd107
OK
Nikuk
    May 23, 2024
    May 22, 2024
