alpine cda-9827
laxmanred
hey guys,
i am trying to put a alpine cda-9827 in a 2005 buick lacrosse...i do not want to cut any factory car wires (including anything on the stock radio), in case i need to put the radio back in it when i sell it. I need the wire harness that goes from the alpine unit to the car wires for speakers and power and everything. any one know where i can get this. or what i should do?
thanks alot.
you will need one of these
GMOS-01
GM non - amplified interface harness. Retains chimes and accessory. Works with or without onstar and provides navigation wires.
GMOS-04
GM amplifier interface harness. Retains chimes and accessory. Works with or without onstar and provides navigation wires.
GMRC-01
GM non - amplified, non - onstar interface harness. Retains chimes and accessory through an on board speaker.
GMRC-02
GM non - amplified, non - onstar interface harness. Retains chimes and accessory through factory door speaker.
XSVI-2003
Non - amplified, non - onstar interface harness that retains accessory power only.
XSVI-2003-NAV
Non - amplified, non - onstar interface harness that retains accessory power and provides navigation output wire.
and the harness that is already with your alpine radio, you will also need a gm antenna adapter.
no, i do not use on star at all. i don't care if it works with this head unit, i just DO NOT want to have to cut any wires with anything that came stock with the car...i want to just add the right harness so that i can swap it out when i sell the car...
laxmanred
laxmanred
Rochester, NY
blue200sx
Mike Mccabe
