A type X might be better for you anyway, They are much more SQ oriented than an R and will excel in a sealed box. I would completely get rid of the rear stage and run a quality set of comps up front with 80-125rms to the, set this will help alot with proper imaging. There are a ton of members in florida also who could help you do the install and would most likely not even charge you a fifth of what bestbuy will, Also by helping them with your install you will a lot about car audio. For the power I would also scrap the idea of the alpine sub amp. You can find 1000rms in the classifieds here for much less money.What Alpine amp would push 1 Type X sub? I'm still not understanding how the ohm system works. If it's 1000 rms x 1 at 2 ohms would this work with the type x which is dual coil and 4 ohms. Max rms is 1000 watts. I want to match an alpine amp with this sub. I like the vids i see with this sub.
Dude, the Type X sub you're looking at is 4 ohm dvc, which means it can be wired to either 2 or 8 ohms. That means you'll need 1,000 watts rms @ 2 or 8 ohms for that particular subwoofer. This is the type of thing you'll learn about once you start doing some actual research...I'm not understanding the ohm deal. The type x is 4 ohm but it can be connected to a 2 ohm amp?
If it says 1000 rms x 1 at 2 ohms but the sub is 4 ohms (with max rms of 1000) doesn't that make it incompatible?
Wouldn't the amp have to say something like 1000rms X 1 at 4 ohms???
Never used DB Drive and haven't used any PG stuff in a long time. PG has changed ownership since the last time I used any of their products and I have no idea if the new stuff is good or not.Thank you that clears up alot! This counts as research yes? Do you know anything about DB drive and Phoenix gold amps? Any good?
I'd rather have the Alpine amps.Fished around a bit for you on amps, since these get really good rep around here
For subs TXA-3002 - Cadence 2 Channel High Power 600 Watt Amplifier
For speakers TXA-3004 Cadence 4 Channel High Power 600 Watt Amplifier
I was supposed to grab these on my build, but I spent more $$$ and went with different
mehThis is what I've come up since the first post, upgraded a bit since I saved some money looking around.
Alpine IDA -x100 - $250.00
Alpine SPR 13s 5 1/4 Component Speakers 129.00
Alpine SPR-17C 6 1/2 95.00
Alpine MRP-F600 $295.00 100RMS x4
Alpine MRP-M1000 $229.00
Alpine SWX-1243D -$221.00
Approx $1220
