Alpine 7995 2v sub preout ?
I thought higher outputs give a cleaner, more efficient signal from the amps to the deck ? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Again, if you don't have a noise problem with 2V outputs, going to 4V isn't going to get you anything.
yes because you can keep your deck volume down to not distort it.. along with gains.. but only helps if clean signal is present otherwise either setup will be bad
also if thats your sub amp only the hpf should be off... lpf i have mine set at 80 it sounds great.. play with it.. find whats sounds best
Im using channel A for my fronts and channel B for my Sub.
Here's a pic of my channel A Gains for front.
http://i33.tinypic.com/ff7595.jpg
ok thanks. I dont have any noise issues whatsoever.
Rob.
Rob.
Toronto Canada
Rob.
