Alpine 7875: V-Drive Question
  • 3
that's to make sure the internal amp gets the voltage taht it needs...
if it doesn't get enough voltage (most stock wires can['t carry enough) then the amp will run hot, not produce the full amount of power and could potentially fry.
Alright... guess I'll have to run a wire all the way to the battery. Do I HAVE to connect another fuse close to the battery? Cuz there already is one on the wire but it's closer to the deck.
you want to run an inline fuse along with the fuse on the alpine. Thats how I have mine setup and havent had any problems at all.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
239
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
553
So far I have bought Kicker CWRT8D4 Subthump underseat enclosure for 8 LoopBack Harness from AIS 8 gauge Kicker wiring kit (Will run two 8 gauge...
13
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
drummer_punk82
drummer_punk82
Michigan
mattj
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
