Sold Alot of cheap audio stuff...
BlueSkivic2
I am trying to get rid of all this stuff so i can get what i really want...
3 JL W3 12 d6
2 10" Blapunks in a ported box
Pioneer 760 amp
Profile BA 400
MTX 12" Road Thunder
1 Farad Chrome Cap Stinger (New)
Fosgare 150s
2 Jensen 10s in a bandpass box
2 MA audio 15s
2 Kicker 8s
2 Kicker Impulse 15s
2 Generic 12s
pm me with offers... most stuff is barley uesd if at all...
Originally posted by Jeremy jl fan can you please give me the specs on the profile amp, pioneer amp?
profile
Signal to noise ratio >90db
>85 db channel seperation
200W x 2 max
100W x 2 at RMS
MOSFET
Built-in 75/1--Hz crossover
Pioneer
-Features -PWM Regulated MOSFET Power Supply -Bridgeable 1/2/3 Channel Capability -Balanced Isolator Input Circuit -Oversized Screw-Type Power/Ground Terminals -Screw-Type Speaker Terminals -RCA Inputs -Hi-Volt Input Level Control (200mV-6.5V) -Selectable Crossover: 80Hz, -12dB/oct. (LPF) -Specifications -Continuous Power (14.4V): 125Wx2 (4 ohm), 190Wx2 (2 ohm), 380Wx1 (4 ohm) -Max Power (14.4V): 250Wx2 (4 ohm), 760Wx1 (4 ohm) -Frequency Response: 10Hz - 50kHz (0,-1dB) -Total Harmonic Distortion: 0.008% (1kHz, 4W) -Signal-to-Noise Ratio: 100dB (IHF-A) -Dimensions: 11" x 2-5/16" x 12-3/4"
Originally posted by mountainbiker can i get prices on the following....
Mtx road thunder 12"
Jensen 10's
MA 15's
Generic 12's
and the kicker 15's
thanks a lot.
as for prices i'll throw some out there but if ur serious talk to me and we can work something out...
MTX-40
Jensens-70(depends if u wnat th box too..)
ma's... make an offer...
gereris 40
kickers 175
Fosgate 150s...
Channels 2
Per channel power 37.5 W X 2 @ 4 Ohms RMS
75 W X 2 @ 2 Ohms RMS
150 W X 1 @ 4 Ohms Bridged RMS
Total power 300 Watts
Bridgeable Yes
Crossover HP 120Hz 12dB per Octave
LP 80Hz 12dB per Octave
Tone controls Bass Control
6 to 12 dB @ 45 Hz
Signal input
Low level -
Quantity - 1
Type - RCA(pr)
Voltage -250mV - 6 volts
High Level -
Quantity - 1
Type - Plug(multi-pin)
Voltage -.5 - 11 volts
Line output
Phase control
Power input Connector - Barrier Strip
Wire gauge - 10
Speaker output Barrier strip
Power supply topology MOSFET /
Output topology
Display Power -
Position - End mounted
Type - LED
Heatsink Type -Cast
Protection Thermal
Short
Overload
Remote control
Class
Marine use
Specifications S/N 100dB A-weighted
Damping Factor >200
Slew Rate 30 Volts/ms
IM Distortion Stereo/Mix mono
Frequency response 20 to 20k Hz +/- .5 dB
Dimensions 2.40 X 9.80 X 10.35 (inches)
BlueSkivic2
BlueSkivic2
Austin, TX
DaBaller504
