Sold Need an amp to run 500w@2ohms
In the price range you can get alot of good $ vs watt combo amp.... One off hand is the jbl 600.1...
Output 4 Ohms: 300W x 1
- Output 2 Ohms: 600W x 1
- Signal-to-Noise (dBA): >100
- Frequency Response (±3dB): 20Hz - 500Hz
- Total Harmonic Distortion: 0.1%
- Input Sensitivity: 250mV - 4V
Is the specs for that and its under $200....
-Matt
I want 500 watts rms, my sub rms is 400-500 so i can't go over 500. And it's a dual 4 ohm sub so its either wired at 2 ohms or 8 ohms
The US Acoustics 800D. Your sub rms is only 500watts 600watts probly arent going to hurt it. The US Acoustics 800D is an awesome amp. You can pick up one off thezeb.com for under $250. It puts out 600watts rms at 2 ohms, 400watts rms at 4 ohms, and puts out extremely clean wattage. It also comes with a subsonic filter. If you think the 800D is too much power go for the 600D on thezeb.com You will not be disappointed with these amps.
i have an eclipse 33230 for sale. it is a top of the line eclipse amp. it pushes 130 wattsX2 RMS @ 4ohms. at 2 ohms i BELIEVE it is around 600W RMS bridged. but you could just turn OFF the bass boost switch. this amp retailed for over $300 new, i would like $160 for it shipped. i do not have the original box or manual, however, it is in FLAWLESS condition. i believe there is 1 scratch on the face that you have to LOOK for. it was never used hard as i listed to led zeppelin and pink floyd, etc. it was powering two RF 4 ohm 8" subs. please let me know if you are interested. it is a 2002 model btw.
Good choice, its an awesome amp. I figured your probly getting it off thezeb.com I've never had a problem with them. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
RFmustang
RFmustang
MI
venom107
