Almost got killed. legit.
let me know how it works, my HF one was a dud
ill let you know. the clamp im binging to the show was on par with the flukes at work. it looks like one and reads like one i think its bstock maybe idk. accurate basterd. and my dmm is a craftsman. 30$ at walmart. best ive spent
beat this..
was at a hotel with the girlly girl //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif and fire alarms went off. You know how it usually is, its a test or an accidental alarm....nope, looked out the window and smoke was everywhere....had to run out of the building. Apparently an air conditioner caught on fire and it set the front of the building on fire. True story bro.
at least I get another free night there
I stuck a screwdriver into a live terminal of a three phase 480V AC disconnect...I didn't die //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Grow a set pussy. Almost got killed by a wall socket? That's grand. If it were 210v DC it would be lethal, but 210v AC is just enough to hurt. Volts don't kill, current does.
OH FOR THE LOVE OF ALL THINGS HOLY
i am so sick of hearing "voltage doesn't kill you, current does". Bro, your body is a resistor. How the fudge is a power source supposed to push any current through said resistor if THERE IS NO VOLTAGE?¿ Scheisskompf.
ITT: bunch of "electrical experts" waiting to get seriously hurt...
to the first guy: the reason your multimeter "blew up" was likely because you had it set to measure resistance, not voltage. changing the leads around shouldn't have caused what you described... it sounds like you created a short (by having it set to measure resistance (ohms)) and the internal fuse blew (like it was designed to do).
with that being said, 120v kills more people annually than ANY OTHER VOLTAGE... like mentioned "amperage kills", which is true. 120v is capable of providing enough amperage to stop your heart thousands of times over. it can take as little as .05 amps to cause de-fibrillation of your heart...
the only reason you guys don't get shocked (and likely killed) when wiring up your stereos is because there isn't sufficient VOLTAGE (12-15v) to send current through your body. the higher the voltage, the more amperage can flow and the more likely it is to use YOU as a source to ground which = electrocution.
lulz....120v won't kill you
Yes it will. It takes less than .001 of an amp to stop the human heart. A typical range operates anywhere from .5-5 amps.
Didn't see this when I posted. Somewhat correct, however: Our body has 100,000 ohms of resistance. Yes, it does indeed typically take more voltage than the DC side we see in the car audio world to overcome this resistance, but a person can be killed by electrocution at 12v if there is enough amperage present and a perfect flow of electricity (arms being the contact and ground point is typical in a car).
You are correct that 120>ground is the biggest killer because most people do not exercise enough caution, and it is the most common voltage people come into contact with. It's like cars being more of a threat than airplanes, as many more people are in cars everyday.
Your last paragraph is half truth. While higher voltage typically does have higher ground fault amps under normal operating conditions, all voltage means is the Potential difference. Voltage is indeed the force behind electrical current, but it also describes the difference in electrical potential. If there is 139,000v (typical transmission voltage), but someone's potential is equal to that; they can get inside the current flow and not receive any negative effects. If there is a 40v DC source, but the person is at a 40v difference in potential, they could receive a deadly shock if they encounter the current flow.
//content.invisioncic.com/y282845/emoticons/applause.gif.bb805d8088f72dbc2fe808c29e85fb4c.gif finally some one who knows what they are talking about...
CAT MAN
Banned
CAT MAN
Roanoke,VA
pickup1
michigan born
    May 14, 2026
michigan born
    May 14, 2026
