Alarm WONT shut-off
purerx7tt
With the battery connected the alarm wont shut-off its a constant sound of the horn going off. I had to disconnect the battery to shut it off, once the terminal and the connector touch it immediately goes off. I disconnected the 8 pin and 20 pin from that alarm module and the alarm noise did go away, but thats just band-aiding the problem. I had to disconnect the white harness that attaches at both door hinges and cut and extend the wires and after that ive had this problem, cant figure it out. Anyone have any ideas?
Thanks
is this an after market alarm? or the one that came in the car?on some oem alarms it will turn off if you open the trunk with the key look in the owners manual.if its an after market alarm take to the place it was installed or to a place that sells/installs that kind of alarm.
dun dun dun dunnn
you probably have to reprogram the remote.. from what i read its not responding, simple fix
1st> connect the battery alarm will sound, turn ignition to run and press the alarm switch 3-5 times, alarm should beep and disarm
2> find the manual for your alarm, then find the remote reprogram procedure... done!
-enjoy
purerx7tt
purerx7tt
naples
Decipha
