Air compressor suggestions...?
i was actually in the market for one around the same price range about a year ago. i ended up getting the husky 33? gal from HD. i looked at craftsmen and all but just ended up getting the husky because i didnt have to order it.
got it about a year ago for about $350 and i love it. use nailers, sanders, grinders, paint gun, cut off wheel. you name it, ive prob used it with this comp. hasnt failed me yet and has a good refill time.
a bit noisy at times, esp since its in my garage. other than that, its perfect for what i need.
I'm in the market for an air compressor. My budget is about $300, maybe more if it comes with some decent tools. I won't be powering any heavy duty tools with it, just nailers, maybe an air sander. I'd like for it to be available at sears, lowes, or home depot, i don't want to have to order this thing.
anyone know of any good deals or anything?
Just so you know, you won't be able to operate air sanders with a $300 compressor. Sanders, and grinders are air hogs and will empty a 20 gallon tank in less than a 90 seconds.
I have this one and it's good for impacts, ratchets, painting, and general air applications:
http://www.grainger.com/Grainger/items/4B227
i beg to differ....i got a kobalt 60 gallon from lowes for 299 around xmas time. a little under that actually because i got my 10% discount too. only thing it might have trouble with is a heavy DA sander.
I can handle you begging to differ. I'm just giving the guy the straight scoop on my experience with my compressor. Is your pump a single or dual stage? If it's a single, I doubt it could handle continuous grinding or sanding.
mine handles the DA's pretty well. i can use my 3'' for about 2 mins continually and then it refills as i go, never dropping below 100psi. it does well with the 6'', runs about a min and then refills but i have to stop about every 5 mins to let it refill a bit. i dont use those too often so it makes the little work i have to do that much easier.
tyler_fitz
They call me Weezer
tyler_fitz
Hutchinson, KS
lostsuspect21
