Air Bags?
Ben_Davis
what exactly do i need for the air bag suspension? cause i look at these kits and their like $1,300, but then i look at the parts seperatly And it seems way cheaper. air bags $50 a piece. compresser like 240. what else is there that makes it so expensive?
this is gonna b on an expedition. i also have a question. my expo already came with stock air bags is there a way i can hook those up to a new compresser and the rest of the stuff so i dont have to install new air bags?
no i wouldnt suggest using the bags that came stock on your expo. they wont beable to handle the pressure or load. they are designed to work together with your factory springs.
ok, heres a list of what you will be needing:
4 bags (i would do slam re7s up front and re8s in the rear)
a rear link setup (many options, but i like 4 links)
compressor
8 valves
switchbox
frame notch
front bag mounts
lots of fittings
tank
pressure switch
relay for the compressor
shocks for the rear
water trap
gauges
airline (for both gauges and bags)
this is just a quick off the top of my head list
o. well so much for that plan. i was thinkin about just droppin it from the front but now i think im gonna save up and buy air bags. Have u guys seen a plug and play kit and airbagit.com? do you think that will work?
Ben_Davis
Ben_Davis
Mesquite,Nv
OneKrazyKeebler
michigan born
    May 14, 2026
michigan born
    May 14, 2026
