those ones i linked too are $10-20 cheaper than 47 bucks at wal mart. odd too when i change my charger off agm @10 amps it will start charging at 15.1 v and when i set it to agm it goes up to 14.6v. agms are not designed to "vent" like a regular wet cell and wet cells often give fumes under normal use. you get an agm battery to vent you have done a little damage too it that you cant replace. that is why they have chargers with agm modes.Not sure why you quoted me but... what you said goes for all batteries. Any battery can be boiled if left on a high amperage without watching it. This can also happen with trickle chargers (which can do other things as well). The only battery that is significantly different is gel-cell's. And the charger I linked to is a smart charger like the ones you linked to, just not as high current and cheaper. lower or higher amperage just means how fast the battery will charge. As long as you have a smart charger you can just plug it in and forget it and it will charge it as fast as it can for the particular battery that is hooked up to it. Though Gel-Cell's need specific chargers.
