after big 3, engine does not start >.>
Tek18
5
KY
need help, just finished up the big 3 and every time i try to start the car a " TINK " happens and the engine doesn't move............... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
worked fine before, and the battery light is on.. odd. but a lot of lights are on when the car is fully off so that may be it.
everything else works !
this never, ever happened before the big 3 so i must have done something wrong :S
try un-doing what you did lmfao..
when i did my big 3, my stereo came on , and wouldnt turn off, even when i started car and turned it off and opened drivers door, i un-hooked the negative, and hooked it back up, and then it shut off normally.. haha
well if i blew a fuse it wouldn't do it at all would it? the starting motor makes a noise and the lights dim when i try but it just doesn't go
Did you cut any of the OEM wiring? Or did you just add the larger wire for the big 3 along with the OEM wiring? I would remove what you have done and see if it starts up and go from there.
OEm wiring?
yes i removed the stock wiring if thats what your asking so i don'thave multiuple grounds etc
Tek18
Tek18
KY
akheathen
