aero ports in a wall?
orangecounty1
due to the complexity of the sides of my box, its going to be kind of hard to build a slot port on the top of the box.
i was thinking, instead of a slot port, should i do like 4 6" aero's? (or whatever i need to get the right amount of port area)
which leads me to my questions.
-if you have 200 (example) sq in of port area, with a slot port, if you switch to aeros, do you still need a ton of aero's to get 200 sq in? or does less aeros equal out to the larger port area of a slot port?
-aero ports in a wall. how will this work? i know one con is i dont get the natural bracing a slot port would provide, but ill deal with that, and add some extra bracing.
-difference in sound? spl? numbers?
orangecounty1
orangecounty1
Tampa, FL
orangecounty1
