Aero port or regular
A circular port is the most efficient shape, next being a square, the more elongated a slot port gets the less efficient it is. If you do a flared port you can get away with a lot less port area than normally would be necessary, and generally people gain output by using circular ports regardless
Love my aero ports! Easy to work with and also you can change the tuning of your enclosure to fit your needs anytime you want.
What do you mean, and where do you get aeroport from. Reason why Im considering this is because I have little room for a box in my Lumiee.
32Lx16Hx19D for two FI SSD and they recommed 1.8 to 2. something for each sub before displacement, and with my custom box, which is built wonderful, I just know It can meet the recommended specs. I think each sub is seeing 1.85 before displacement.
An example for what i was saying is for myself i plan to have a lower daily tuning for my ride.. And for comps I am going to switch out my aero ports with a different set of ports tuned to a higher freq. In that reguard I like using aero's. They also take up less displacement than using a slot port so if space is an issue they could be more benificial for you. There are a bunch of threads with good info on the forum that could answer most your questions you might be having.
thats my reason for wanting to do aero ports for my next box. they displace almost nothing as compared to like 1cube that a slot port would take up. and you can change the tuning easily
Enellz
The Triple O.G.
Enellz
Louisville, KY
skmfkr
