Aero Port Help
the727kid
Alright, I want to switch to Aeros from my slot port to give my subs some more airpsace (2 15s with 5.5cubes is a little small for me).. anyways could anyone help me out here, I know how to design a slot port but not a aero port. How many would I need to get proper port area and the length for say 31-32hz? Box is 38.25wx16hx24.5d
Alright.. Didn't want to start a new thread.. so here goes..
Will it sound like shit if I don't flare it??? like.. I'm curious, how would it be different from a slot port? Just seems like the easiest most effective way to go, I just don't want to buy Aero's
I guess I could flare it, but I will have a couple Q's about that *** well.
You don't need to, just follow the 12-16 sq. in. of port per cubic foot rule. Put some 45's and you'll be golden. Slot ports are cheaper by far. Aeros tend to add extra costs towards the enclosure. But they do tend to make tuning easier.
Quick question about tuning aeroports I have... Goes along with the OPs post.
When finding the tuning of a aeroport, is it still the same as just finding the tuning for the length?
For example:
Say you have a 2 cubic foot box, and it has 2 4" PVC ports, non flared. If in this instance the inner diameter is 4" of each pipe, that would follow as:
3.14*(2)squared = 12.56. 2 ports would be 25.12sq in of port. Say that gives a tuning of 38hz.
If you used 2 aeroports of the same length in that enclosure, that had the same 4" inner diameter, would it still be tuned the same? Or tuned differently since there is a difference in airflow?
Thats where my question stems from. You need less port because of better airflow.
And since its better airflow, does that effect the length it needs to be to achieve the same tuning?
The length to port area relationship essentially stays the same regardless of port shape. So if the port area of the tube ports was the same as that of slot ports, then the length would remain the same. But because you can get away with less port area, you'll be able to use shorter port (if you do use less port area), since port area and length are positively correlated for the same tuning frequency.
the727kid
the727kid
St. Pete, FL
yunvme666
Mike Mccabe
