Aero port help, Sundown SA-8V2 build
memphis_vette
Looking to get my box done for when my SA-8v2 gets here. I'm looking to do .75 cube box tuned between 30-35hz using up to 870rms. It will be under the rear seat of my 08 silverado ext cab. What would be the best size aero? I was thinking of doing a 4 inch aero but it would have to be external. Any input or advice? Never used aero ports before. Thx
with a box that size you can get away with a 3" aero.
I was told that I might get port noise using a 3 inch aero, any insight? If I use a 3 inch then I may get away with using it as an internal aero rather than external ( which I would rather do since it would be cleaner), my plan is to get as loud as possible and sounding **** good doing it. I listen to a lot of rap and rock, what would be a good frequency? I was thinking either 32hz or 35hz
I was goin to use a 3" aero in a .75cuft box tuned to 34hz. It was like 16 or 17in long.
Sub didn't fit, mounting depth issue, so I can't tell you how it sounded but in theory, it would've worked.
You do realize how long the port will need to be for lower tuning? Longer then anyone will want it to be for sure. A flared port has to be even longer do to the flares.
I would guess around 18-20 inches long for low tuning.
memphis_vette
memphis_vette
Redding, CA
memphis_vette
