aero port avalanche 18 question...
tremor1127
Mental Member
294
TX
i was going to build ported box for my avalanche tomorrow using PVC for the ports. no flare at either end. straight pipe.
how many and how long for a 28hz tune if the box is 6.4 cu ft. would like to use 3" or 4" pipe and i have to keep the amount of ports to an equal number...
thanks...
oh, it looks like it will work for straight also...
hmmm... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you get some flared ends you can go with about 50% less port area:)
Try to go for about 16 in^2 per ft^3 of volume. A 4" port has ~12.56 in^2 of port area. I would try to do around 6 ports but that may be difficult with a 28hz tuning because the ports may need to be a bit longer.
tremor1127
Mental Member
tremor1127
TX
Lakota
