Advise me if Im doing something wrong.
alago
This is my first post on this forum... first of many, hopefully. I just got a hold of a bunch of stuff that I am planning on installing, and I wanted to make sure all the wiring was okay.
  • JL 500/1
  • JL 10w7 in 1.25 cubes
  • PPI PC450
  • Scotche 1 Farad Cap
Now, tell me if this sounds acceptable:
Battery Terminal Post with 2 gauge wire running to distribution block in the trunk, 4 guage from distribution block to each amp (fused), and 4 guage local grounding for each amp...
1. Should I run a ground distribution block or should I go with local grouding?
2. What size fuses should I be considering for each 4 guage line to the amps?
3. Is the 1 farad Cap necessary or should I consider going with something like the Kinetic?
Any and all advice is appreciated. Frankly, I haven't done car audio since high school and I feel like it has changed a plenty.
Cheers.
  • JL 500/1
  • PPI PC450
1. Should I run a ground distribution block or should I go with local grouding? IMO, local grounding
2. What size fuses should I be considering for each 4 guage line to the amps? Fuse should be located within 12" of battery
3. Is the 1 farad Cap necessary or should I consider going with something like the Kinetic? IMO, cap shouldn't be required, may want to get your charging system checked first - AutoZone etc can do this for free
Cheers.
Posted my opinions
Lose the cap, if you have dimming do the Big 3 and maybe add a kinetic.
I'd use a 300amp fuse close to the battery incase you want to upgrade. I've got one for 10 shipped if you want it. It uses 2 150amp fuses....
  • JL 500/1
  • PPI PC450
Cheers.
if your amps have on board fuses, there should be no need to fuse the 4 gauge runs... i'd ground from the amps, no need to ground the distro block imo... the cap is unnecessary, i'd bet you wont even need a second batt, depending on the car, your electrical should be able to handle it. maybe try the big three? caps are useless...
Cheers, I was hesitant to put that piece of *** cap anywhere... anyone intersted in buying it for hmmm $20.00? hah.
Are the proposed wire guages correct? overkill?
Im installing this in an 02 WRX.
Cheers.
Correct me if Im wrong:
The big 3 upgrade is upgrading the guage of three OEM wires, does this affect the rest of the cars charging system? I assume not. However, wouldn't I be putting a hell of a strain on my battery/ alternator? Could I upgrade the battery to counteract this effect?
... and Im sure there are tons of threads about this, however Im wondering if theres a quick reply.
So far Im impressed at the level of activity on this forum and how quickly Im getting responses back.
Cheers, guys.
The big 3 upgrade is upgrading the guage of three OEM wires, does this affect the rest of the cars charging system? I assume not. However, wouldn't I be putting a hell of a strain on my electrical batter/ alternator? Could I replace the battery to counteract this effect?
Cheers, guys.
Not upgrading, adding..and it will help ur charging system. You could alwasy just add a kinetic or yellow top.
Heres a pic of the voodoo, page 8 top anl fuse holderHere
alago
alago
Austin, TX
Wkbdkid
