advantadges/disadvantages to inverterted sub loading
nothing wrong with it...just take into effect that you now have a larger enclosure, the sub's displacement is no longer a factor. Other than that, nothing's different.
Now, if you have them set up normal and one or two inverted, you need to reverse the phase on the ones that are inverted...
I heard doing that will increase SQ but decrease SPL. //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
It wont increase SQ unless the sub operates better in the slightly larger box in now has when inverted. SPL will not go down audibly, sure there is ever so slightly less cone area do to the motor assembly but you shouldnt hear it.
You heard wrong. If anything, the SQ goes down a bit as there is more chance for motor noise. But, as was said above about changing the enclosure volume, this means SQ could be positively or negatively affected. Most likely, either way you wouldn't hear the diff anyway.
disadvantage = subs sticking out of the box take up more room //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
disadvantage = the subs are probably going to be all chromed out which means you will probably be running audiobahn. and thats never an advantage.
Very good perspective....
lol,
well, if you need an extra .1 or .2 cubes, and your box cant go over the rear seat (SPL- or prefrence) invert the driver, and you gain a bit of room, and get to look at the purdy motor.
really no audible difference, basically looks.
lol,
req; clear your PM box fool!!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The RF PWR412.... (The Older ones)
they actually arent audiobahn, but 3 ten inch JL w3v2. i know the basket isnt as asthetically pleasing as others, but i think it would look cool nontheless. i built the box myself, and each chamber is about 0.75 cubic feet. oh yeah, my car's an suv, so its open cabin. any other suggestions with this information?
bcarpenterfhl
Kiss Me I'm Shitfaced
bcarpenterfhl
San Francisco/Hillsborough, CA
audioholic
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
