Adire Shiva.. pushed by...?
Originally posted by ss3079 I'm running an ARC Audio 1500D-R to my Shiva's and they are fine...
- Steve
To be honest.. i havent even found them yet... im going to look right now,
It is such a kick in the *** to be looking at some really hot amp.. and than to realize NONE of them will fit the needs to my sub..
Originally posted by cobra65427289 maybe i just skimmed over all the replies too fast but, what about an avionixx 800.2, it pushes 800 rms @ 4 ohms. but it does lack a SSF.
al
Nope didnt over look anything, SSF. Think that would be a problem? i have an Equilizer.. (
lol, basically what it's sayin is that you can only wire it down to 4 ohms and can only wire up to 16.
Because you can't wire two 8ohm subs down to 2 or 1ohm, Now if you had some 4ohm subs you could wire them down to 2ohms and up to 8 ohms....
I hope that made since, I would still go wt the jbl though.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif But thats me.
Originally posted by djjdnap lol, basically what it's sayin is that you can only wire it down to 4 ohms and can only wire up to 16.
Yeah thats what i thought. I wasnt sure if i was missing something, Im tring my hardest to learn here.. but sometimes it just gets soo confusing. Im tring to Figure out what amp to get, so i get better sound Output.. but now im limited to Amp that i have NEVER heard of for prices so rediculous.
Your Right about that JBL. it is the best bang for my buck from what i can tell. I did alot of searching. The JBL has the best Frequency range.
The only other two amps i have found so far that are good too Is the Profile CL1200, and the MTX 942 (bridged). That MTX has a nice Output.. for its price.. but im unsure about its Quality compared to others.
Avionixx and and Arc have supposed good amps. For 500 Dollars.. (ouch) IM still searching just in case tho...
I just cant believe that all the amps i was really hyped about getting are no good.
Hey if anyone knows of a good amp for cheap.. please, mention it. (High Watts @ 4ohm)
i meant http://www.purecaraudio.com
there prices are low but not as low as the stores on ebay..
it's 279$ for the jbl 1200.1, and you said 4ohms so it's 600 watts at 4 ohms.
But 600 watts should be enough.
I have one 8 ohm rockford and i just turned it up today and it beats, i still have yet to crank it all the way because i don't feel like drivin back to best buy to get another one. hmm it still hasn't been 30 days i should get my money back so i can get my orion h2's.. i thin ki'll do that tommorow. ....dam i gota get a physical so i can go to football practice tommorow:banghead: not enough time for the fun things in life
why dont u bring down the Ohms and REALLy crank it!
http://www.rockfordfosgate.com/rftech/wiringwizard/index.asp?WoofQty=2+woofers&WoofImp=Dual+Voice+Coil+-+4+ohms+x+2&image.x=12&image.y=10
sorry for the large link..that might help..
Ever get those H2's?
Hey, how would i setup stereo on my woofers? is it possible? I'd need a two channel right?
no h2's ebay is actin funny on all the orion h2 sites it keeps sayin invalid item,,, so, i don't know, i still need to take my sub back and get my money so i can buy the h2 though, them thirty days is windin down,:eek:
What do u mean stereo?????
Originally posted by djjdnap Because you can't wire two 8ohm subs down to 2 or 1ohm, Now if you had some 4ohm subs you could wire them down to 2ohms and up to 8 ohms....
Correction here. Shivas are DVC and each coil is rated at 8 ohms. You can get 2 ohms out of 2 Shivas if you wanted to.
SubCool
SubCool
NY
Mr. Loki
