Sold Adire Revo 1500/RE 35.1/BEtter Audio 1600
zachzchw
Selling my Adire Revo 1500, same amp as the RE 35.1, and BEtter Audio 1600. Rated as follows:
500 x 1 at 4 ohms
1000 x 1 at 2 ohms
1500 x 1 at 1 ohm
These amps usually do about 1550 or more at 1 ohm. Comes with original box and remote bass boost, autographed on the bottom by the owner of Ampman.
You will need to repair the amp, Id recommend kbaudio.com.(Repair will be $100, the repair will come with a 30 day warranty, you can extend it to six months for $20.) The speaker inputs only put out 6 volts, so no sound from the sub.
Trades will be considered, Im mainly looking for an amp to push my 15" XXX, and would like to have at least 1000 watts rms at 1 or 4 ohm.
No set price, just make offers.
killer amp very strong... will do .5ohm daily //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
im running one of its many sisters //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Any clue on the power output at 1/2 ohm? Is the 1550 in line with what you know of them? I havent been able to find anyone with a birthsheet, just based the 1550 on what Ive seen other people say.
Also, this amp can be modded........not sure how, but Ive seen it mentioned before.
Any clue on the power output at 1/2 ohm? Is the 1550 in line with what you know of them? I havent been able to find anyone with a birthsheet, just based the 1550 on what Ive seen other people say. Also, this amp can be modded........not sure how, but Ive seen it mentioned before.
I'm also curious to this amps output at .5 Ohm.
if this amp, internally, is identical to the RE 35.1d (which by the looks of it, is), your power ratings are slightly off
quoted from RE:
at 12v:
4ohms, 350RMS
2ohms, 1100RMS
1ohm, 1600RMS
as far as i know
Probably just rated different by the different companies......
Ive always heard that this is the same amp as the RE 35.1 and BEtter Audio 1600, they just use different heatsinks.
zachzchw
zachzchw
ohio
zachzchw
