I have a 08zx700.5 amp the birth sheet has it rated at 984 max output.
1.)I have 2 12 comp (yellow) 4 ohm wired in parallel for 2 ohm load the specs say they should be getting "2 ohms: 420 watts x 1 chan" but since the birth sheet is rated higher are the subs getting more power than the 420 watts? Is the same true/false for my speakers?
2.) I want to add some kicker ds 6.5 4 ohm to my Jeep. I already have 4 5250 4ohm speakers each on their own channel, should I parallel the 5.25 and give the 6.5 its own channel?
3.) I have no bass coming out of my speakers so would getting the 6.5 components make a difference?
Thanks
Thanks
