adding rear battery, ground to front batt or chassis?
hey also i was wondering what size fuse between the batteries? not to jump in but wondering?
Fuse for the wire, generally if your running 1/0 gauge fuse with 300a. I wouldn't really trust a smaller wire to connect batteries, but some people may do 4 gauge. If so fuse for 4 gauge. If running 2/0 fuse for 2/0, etc.
some vehicles are better to ground to front battery since its less resistance than the chassis ground depends on how good of a ground you can find and use, and the vehicle, i grounded to the front battery helped my voltage alot, in the back grounded to the frame the battery at full tilt would drop to around 12.2-12.4 grounded to the front and it stayed from 12.5-12.9
not the greatest but not bad considering stock alt and only one battery in the back on 2200rms
i want to run 1/0 pos and neg from the front batt to the rear batt and my friend is saying to just ground to the chassis.
Ive been told never to ground to chassis, make 2 runs of 1/0 from positive and negative of both batteries in parrallel.
i don't follow. why is it different? (mine is unibody, grounded to chassis)
Unibody you don't have a full frame running front to back...you have a rear sub-frame and front sub-frame, tied together via the body in the middle.
Full frame you just have more continuos steel running front to back without body mounts, etc in the way of electrical flow
who lied to you?
makes since. works for me though so it will stay until the upgrade
I'm just too lazy to run another run of 1/0 to the trunk lol
Some people notice a difference after grounding it to the battery and some don't. Just depends on how good of a ground you can get on your car
skmfkr
skmfkr
Savannah, GA
jrwalte
