adding magnetic contacts to alarm
MyFartsStink
my farts stinky they are
We want to add some magnetic contacts for the the work trucks rear hatches. There is three total and the magnetic contact is normally closed when they are apart. I want to hook them all up in series with a 12 volt and a combination of a relay to send the alarm door trigger a negative signal. I have a wiring diagram of how I just only hooked up one of them to see if it would work first. It seems like I got it right, but I cant get the alarm to sound when I test it. I hear the relay click every time I move the contacts close to each other. I dont know what I am doing wrong can someone help me fix this problem?
there is no purpose for a relay in this application simply wire them to the alarm and diode isolate
Are you saying I should hook up one lead to a ground then hook the other to the door trigger input through a diode? If so I already tried this and it didn't work.
MyFartsStink
MyFartsStink
Oklahoma City
THUNDERBIRD
