Adding Backlighting
  • 4
sharp21
Starting to plan my next box, a wedge with 2 subs & a recessed amp for a regular cab truck.
I would like to add light rings around each sub, backlighting under the amp so it looks like its floating & Dodge Ram symbol above the amp.
Can somebody point me in the direction of how to go about this? Any pictures or examples I can look at?
I figure it will involve some kind of trim piece that covers the whole box front...
Also, whats the best way to go about powering the LED's?
Thanks
S.
974
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
800
Thanks. That makes sense. It sounds pretty good as is.
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
sharp21
sharp21
Alberta
sharp21
