Adding another electrical component to same power line?
Tune78
I have purchased a sound processor and I'm wondering how I should power both my amp and the processor?
I had a friend tell me to add a battery in the back then branch off from that batteries post.
I originally thought to instal a distribution block for the two then branch off to both with different fuse sizes from the block.
Which would be the best way to go?
Only reason i dont want to do the battery if i dont have to is because i dont have much room in the trunk as it is...
Also what fuse sizes for everything
my amp came with a 100 AMP fuse. I'd assume a 20 AMP for the processor. If i run one line to the back what fuse for the main line?
I have purchased a sound processor and I'm wondering how I should power both my amp and the processor?I had a friend tell me to add a battery in the back then branch off from that batteries post.
Distro should be fine. 4g OFC will handle up to about 150A. Split 4 --> 4, 8 for amp and the processor. If you go that route you will want a distro with a 150A and 60A fuse.
Tune78
Tune78
Denver, CO
Kangaroux
