I want to add an ignition switched accessory wire from the fuse box (I'd rather not tap into the cigarette lighter). Apparently I have to bypass the Metra wiring harness for my jeep because there was a bad batch that caused the h/u to turn on and off at random. So I have to direct wire the 12v ignition/acc. Anyone have experience with these "add-a-circuit" fuseholders? I'll plug this into a hot switched open fuse terminal:
Is this the safe way to go or is there a better solution?
