Adding a Clipping Indicator
J3M Concepts
****** Intellectual
528
I was looking at a pro-audio board the other day and knowticed an led on each channel to indicate that the input signal of the channel is being clipped.
I was wondering how hard it would be to do that to the outputs of my headunit.
Is it as easy as parallel wiring an led into the rcas or what?
My headunit is rated at 5v peak so would i need a 5v led? Would adding such introduce any kind of noise or interference into the signal?
What do you think?
Tripp
Most processors only tell you when the outputs are hitting the design peak. A few have actual clipping indicators. If the LED isn't labeled "clip" or "clipping" don't assume that it's anything other than a peak indicator. It won't tell you if the input is clipped and won't do squat for the amp output.
J3M Concepts
****** Intellectual
J3M Concepts
helotaxi
Mike Mccabe
