adding a battery... have a few questions
impaled
FL
i am going to be getting a yellow top (as a second battery), how would that work with my stock battery? what is the best way to wire up a second?
i have seen a few different options such as this: http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1333954/vpcsid/0/SFV/30046/sret/1421521421516219214211282227222283216223218287218235218291236237296225230225236237230229234239242243240
or could i go without that and just wire them together?
would anything be hamed by having two different batteries?
see ya got triple j revised u know its me in ur sig
u really want to keep bats the same if u can
if u are gonna be using the system alot with the car off get a battery isorelay so it wont drain the main battery this is not necessary tho
make sure if ur putting 2nd batt in trunk to fuse up front within 12" of front bat
and in the rear less than 12" before rear batt to protect ur shit
It'll work, but I highly DO NOT recommend running and AGM cell with a regular wet cell.
Wet cells usually sit at about 12.7 volts when fully charged, AGMS typically sit at about 12.8 volts or a bit higher when 100% charged. What this means to you is that the AGM will slowly discharge into your wet cell and the AGM wont stay fully charged when the car is off just sitting there.
You wont run into problems starting your car, but AGM's will die quickly if not kept at a full charge. If the AGM is constantly only about 85 to 90 % charged due to discharge into the wet cell, you'll shorten its life span from sulafation build up.
I run an odyseey 1500DT and a 2150 and voltage stays around 12.9 volts fully charged, if I were to hook up a wet cell that stayed at 12.7 charged, these batteries will quickly dishcarge with the car off to the 12.7 volts which is about 90% dishcharged for the AGM's.
The quickest way to hurt AGM battery performance is to not keep them 100% charged on a continual basis.
The thing is WHY??
Just get two kinetiks, the prices I have found locally are cheaper per AH than Optima.
My opinion is that Optima is overpriced marketing BS.
If you want spiral cell, get an exide. Spiral cell hasnt been proven to do anything but to give optima a marketing point...
The brand really depends on what your looking to do with your system.
Odyssey, NSB, and the powercell and some others are known for the low ESR that gives better voltage drop when drawing instant high current for SPL.
If your looking for better reserve capacity for parking lot pounding and playing moderate volumes for 2-track parties then get something with lots of AH rating. I dont look at reserve capacity at all. AH rating I think gives you a more realistic view of how the battery performs with different current draws over time.
Either way, you want the lowest ESR rating you can get, this means you gotta pay lots o money compared to the other AGM cells.
You can get a lifeline marine AGM battery thats got GREAT reserve capacity and cheaper than the rest, but for instant 300 amps of current, the voltage will sag more than the expensive brands. Most batteries are made to draw 20 or so amps for a long time cause that's what the market is looking for such as trolling motors, lights and such on a boat, powering a solar power application, etc. HOWEVER they dont perform when drawing several hundred amps in a millisecond though. High power car audio demands current in hundred ampere instantaneous spurts, the market for batteries that can do this is VERY small. This is why you pay a premium for batteries that can do this.
In my experiance, optima is overpriced for what it is. Kinetik from what I have heard is better at long reserve times than for instant 300 amps. I run odyssey and they seam to be good at both high amp right now and long reserve times. But really any AGM is better than a wet cell for car audio
impaled
impaled
FL
SPL15
