Added amp for speakers now volume changes with bass
Relex
Today I added another amp for my speakers. I also have a 1200 watt amp running to my two 10" subs. I got everything up and running but now when I change my bass level from my head unit my volume goes up and down too (I know why, read on). When I ran the wire from behind my head unit, I connected it to the one that runs to my other amp for the subs since that is the only one that works. I have another wire that isn't used out of the back of my head unit which says Ant Rem Max 0.1a (don't know what that means). I've tried hooking the wire for my speakers amp to it and the amp doesn't get power and same with the amp for the subs. The only way the amp runs is if I run it off the same wire for my sub amp.
Is there a way to fix this? It was nice so when I would listen to rap I could turn the subs up and for rock turn them back down. Now its just as good as another volume source..
I'm so confused, why does my speaker volume go up and down when I adjust the bass up? If I move the bass all the way down there is no bass at all along with volume.
When I ran the wire from behind my head unit, I connected it to the one that runs to my other amp for the subs since that is the only one that works. The only way the amp runs is if I run it off the same wire for my sub amp.
Can you explain this better:confused: Is it the rca you are talking about? You will need separate power and ground wires for the new amp also if you did not run those already.
rcas should be going to left and right input, not + and -, thats is for spaeker wire or power and ground wire.
Opps, it is right and left.
Heres what I'm running
12+v to cap to distribution block then out to each amp
along with the RCA's split to each amp
Relex
Relex
State Collge, Pa
loopkiller
