add rear deck speakers with sub in trunk...
hondarider
Ok so right now my stock rear speakers are removed and the holes are acting as ports in the rear deck for the sub upfiring beneath it. I had the idea to add a pair of 6x9s with an amp for the rear with a toggle switch to turn them on and off for when people are riding in back or if i want it really loud without regard to sound quality. I was wondering if the speakers would work very well with all the pressure on the back of the cone from the sub?
no, put them in an enclosure if running alot of powerzzz
And what ever speakers you get will be designed to run IB, so they would require a rather large enclosure to not destroy their low-end output. My suggestion is leave the rear deck speakers out.
Times two.
Your fronts should be loud enough to fill the whole car //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
hondarider
hondarider
glidden, IA
audiobahnuser18
